Frame numbers
hi, Iâm building a prefeatherbed single based on this frame
Am I correct in thinking the frame is a 53 ES2 and is the over stamping on the gusset normal and what is N and B ?! I intend to use a model 50 engine - pic below (is it a 57?)
Any help would be appreciated!
Dan
Yes Dan, you are correct. A 53 ES-2 frame. I have several frames with additional numbers and letters stamped where you show them. Don't know the reason why they are there.
Thanks Ian, so does anyone want to swap a pre featherbed M50 frame for an ES2 frame? Not essential but better if I can.
Dan
