Has anyone got information on the dominator red in powder coating .I can get from rs paints the correct norton red for wideline dominators , but would like to do some of the parts in powder
Rs cannot help on this . I dont think any powder coating firms would be happy to give this information out unless i put the work thier way I have a source locally but they have said they need the ral or bs numbers, if i have to go further afield so be it but would like to sort it with the local supplier if poss
Hello powdercoating is hor…
Hello powdercoating is horred stuff norton postoffice red can be bought for Nu-Agane Bedford Bedfordshire phone 01234 355990 Or vintage paints phone 01902 843444 I hope this helps Allso when Spraying paint whare a resperater at all times and only do thin coats do not try to do it in one go you will spoll it drying time 30 min too 1hour in between coats start with P182 isopod zinc primer 3 too4 coats let dry for a hour temperature 60 to 70 f air presser 40 to 50 PSi but frist spray a old tin can or somthing if you can get a good finish no that you are harfway there , have fun yours anna j dixon
