Does anyone have a camshaft breather assembly, the one for my engine is missing. Thanks
Lucky lad!!! They must hav…
Lucky lad!!! They must have got your invoice wrong.
The cost of the disc and spring, from them, plus P&P, etc is nowapproaching £40. I got three new ball bearings formy gearbox for less than this. Which is harder to manufacture?
To me this is another example of 'rip-off' pricing!!!
Hi Phil !! I usually order…
Hi Phil !!
I usually order a bunch of parts at a time & take advantage of the "the more you buy, the more you save" program. The disc is currently 25.38 GBP & the spring is 2.48 GBP (before discount). I feel the price is a bargain. The dis is not a stamping, but a pricision machined part, where someone has to take a piece of barstock on a lathe machine the O.D., counter bore the I.D.,take the part yo a milling machine to machine the 2 tangs, back to the lathe to then cut off to length, then either have a custom punch & die made & punch the 2 special holes, or go to a cnc mill and have them machined. Thats a lot of work for 25.38 GBP. When I needed mine, I searched here in the USA & the part number didnt come up on any of the websites over here, and if it did, they tend to overcharge us over here for British parts. I can usually buy in the UK& pay shipping for less than I can buy over here.
Have you found the breather & spring cheaper somewhere else? And is it made correctly? Let me know. As to bearings, well thats a whole other animal !!!!!!! It has to do with how common a bearing is. A single row wheel bearing #065542 is what, 7 GBP ? I needed a bearing for an electric motor that was 1/2 its size & cost me 5 times as much !!! Crazy, but true.
Skip Brolund
I don't have an extra, but mine was also missing, gremlins no doubt took it!!! I had to call Norvil & got all new, & the price was les than I expected.
Skip
