I'm having rear mudguard stays made for my 1952 model 7 but need some info on sizing if possible. I need to know:
1 the distance between the top two fixings into the mudguard (measured radially around the curve of the mudguard)
2 the distance between the mudguard and the inner side of the stay at the widest point of the curve (out the way) between these top fixing points.
Hope someone can help
thanks
Hi William, You're unlike…
There are sets of these av…
There are sets of these available on ebay but they are not the correct radius and shape, but can be made to fit. Realistically you need to borrow a pair to copy if you want an original looking item. They are not as easy to have made as you might think.
Thanks for your replies. I…
I have now made contact with the Model 7 forum so will see where this takes me.
Hi William,
You're unlikely to gain an answer on here. You need to ask a specialist site like https://groups.yahoo.com/neo/groups/nortonmodel7/info
All variants of the M7 are represented here.
Jim
