Stiff clutch
Nearly finished refurbishment of my Mk.3 and slightly worried about the amount of muscle required to pull the clutch lever in!
the cable is nicely routed and lubricated, with the adjustment as per the manual.
From previous posts, I understand the clutch stack height will make a  big difference.
I see RGM do a 3 & 4mm plate. What should I go for, is there a chance the 4mm plate won't go in if there is little wear on the original plates? And does the new plate replace an original or go on top?
Any advice, other than building my hand muscles, would be greatly appreciated.
