          I'm having problems selecting gears , and the box sometimes gets stuck in gear .
Stripping down reveals the selector rod shaft loose in the thread at the back of the main case .
If tightened down the shaft will not line up with the machining in the end cover .
Any suggestions for a remedy ? Or are they all like this ?
All else in the box is pretty good . Camplate and selector forks are fine .
