The bike is a 1972 commando.
I replaced the lay shaft bearing in my gearbox about a year ago as it had failed and at the same time I ordered the full gearbox overhaul kit from AN (06.7279) and index plunger spring.
All the time I’ve had the bike 11 years +, it’s had an issue with jumping out of gear mostly between 2nd & 3rd when accelerating harder than normal and will happen a couple of times during a ride. It will also jump out of first occasionally if I’ve come to a stop and selected neutral and then selected 1st to pull away.
When I had the box apart I did not see any noticeable wear on any gears or selectors but as I’ve not pulled a box apart before I do not know what to expect, the bike has done 27,000 miles.
I was hoping the rebuild would have solved the issue but it has not.
It’s something I can live with but it would be nice to have it working properly.
Jumping out of gear...
... is often caused by wear on the dogs meaning that instead of presenting a square face they're slightly tapered. As I understand it, the index plunger and cam wheel only provide the correct position when changing gear and have no effect on keeping any gear engaged.
