just replacing kickstart pawl. Removed the mainshaft nut, and it appears to have remains of a seal attached it.
Where is this from? I have looked at Andover Norton gearbox diagram, and can't see it.
Any suggestions?
Bearings are availiable with…
As Roberts suggest it the…
As Roberts suggest it the seal dish. bung it in the bin . and rebuild
Bearings are availiable with built in seals that can be removed if not needed . Should have been removed.
