valve rocker position
just rebuilding my head and like a fool i didn't take notice of which way the flat surface with the hole should face.
can anyone advise?
cheers
Mick
I take it you mean the flats on the rocker spindles
As you no doubt know, they should face the relevant rocker covers — i.e. inlet spindles with the flats on the rearward side, exhausts on the forward side).
But if you don't recall how you fitted them I'm afraid that as far is I know there is no way of telling by looking at the spindle ends as they show in the head. I fear you will have to take them out and do it again.
Hi Julian,
thanks for that. i haven't fitted them yet as the head is away getting vapour blasted so i will now be confident i will put them the correct way.
cheers
Mick
