The petrol tap on the light weight has a unique thread into the tank. 3/8. the club sells 22061 (with standard 7/16 to Amal pipe.
Has any one with the same threads but with a reserve function? Also being fussy I would like a horizontal outlet.........
I have a ewarts 2 position…
Lightweight Petrol Tap
I have previously owned a few lightweights and I think the type of tap you want is the Ewarts type shown in the pictures. This has a pull and twist action for the reserve. Sadly I don’t have this tap anymore as I sold it but hopefully it helps you when looking for one
cheers
Simon
That thread certainly looks…
That thread certainly looks the same as mine. I do think a threaded pipe connection is more suitable though. Going to look closely at some early road tests of lightweights as just about every restored /used bike has a different tap.
Awaiting your investigations.....
Robert-we await your investigations. But of course seeing a picture and getting one could be a different problem. It looks to me that these things were synonymous with petrol lawn mowers. My present on has a threaded out let in line with its body, leaks. But no reserve. It has a pull on.I don't mind having a 'turn on' but we must match the threads and reserve?
1/8 bsp with reserve
Alan,
I know it doesn't look like a leaky Ewarts tap, but this is available on fleaBay for £16.00.
Oh, and you will have to bend your fuel pipe upwards as it feeds from the bottom. I had one like this on my Honda 250 in 1972 and the downward facing outlet is real handy when refilling the petrol Optimus stove.
""Classic 1/8 BSP British Motorcycle Moped Fuel Tap Matchless & others Reserve NEW""
PS Same source found a tap with horizontal outlet. 1/8 BSP. Same price.
""Classic 1/8 BSP British Motorcycle Moped Fuel Tap with Reserve Horizontal Exit""
Hi Alan , after studying …
Hi Alan , after studying many old photos I agree that Simon has the "correct " style of tap in his pictures for a 250 . , not sure if the same applies for a 350 . My tap has the same correct main and reserve action but will need an elbow at the bottom to give a horizontal outlet towards the engine.. If you want it I could swap it for an electrical gismo from your stock!!.
1/8" bsp fuel tap
Hi Peter,
I have one of these fitted to my Navigator and it works ok so far. It can just be seen on the photo in My Navigator Project posted a monthe ago. Pic attached showing lever positions in anyone is interested.
Stan
I have not found reserve…
I have not found reserve taps (unmodified) to be very effective. Usually only enough fuel left for a couple of miles . The ewarts one also allowed a very slow seepage from the reserve to the main function so a very economical bike could actually continue running till the fuel ran out without you being aware although some symptoms of weak mixture were apparent.
For Al Osborne, I’ve got…
For Al Osborne, I’ve got this available if you still want an ewarts tap with reserve. Bought it a few years ago but now realise I’ll never fit it to my Jubilee, the horizontal outlet would foul my under tank keyswitch. Any use to you?
Bruce
That does look to be the gen…
That does look to be the gen article, If the plunger is not pretty tight you are better off renewing the cork . Don't bother looking for a new plunger . I bought a box full of them and even unused they still need new corks.
Many thanks for efforts and advises so far. I did look about the recent Copdock show for something-nothing. Have studded the offers on fleabay and offered hear, and many are the options. Thanks to Bruce as well, but the inside feed doesn't have a thread. So I am still searching.
Plunger
Hello all,
I revived this older thread because I need some help!
I have the same petrol tap with the side outleton my 1959 Jubilee deluxe like the one Bruce shows in the pic.The old cork inside needed replacement so I removed the inner part of the plunger.
Unfortunatly I broke off the part which goes into the pull out handle. I managed to find a brass square tube which I soldered on the part where the cork sits.
Now I need a picture of the whole assembly which shows the orientation of the plunger in relation to the groove on the handle where the locking screw from the tap body goes for correctly assembling the plunger.
Any help appreciated! Thanks!
Uli
Hi Ulrich, Sounds like you…
Hi Ulrich, Sounds like you have realised that the plunger can be reassembled in different ways, and only one is correct!. I can probably take a photo on my phone and get it sent to your phone if you PM me the no. Anything else is too IT for me. If all else fails i can give you a spare plunger, As you have no doubt found out this extended plunger is not availiable , probably my fault as i bought up any that came up.
Hi Ulrich, The picture of…
Hi Ulrich, The picture of plunger in Alans post shows the forked brass end fitted 180 degrees out compared to my NOS ones . Done it myself when fitting new corks. The corks need to be a very tight fit as they soon loosen up . I buy a bag of corks and size then using a micrometer , I soak corks in warm water and coat with some bar soap Seems to help. Dont lose the tiny screw as they are more complicated than they look. Plunger taps have a habbit of turning themselves off with vibration so I pull and slightly turn. Its possible that the difference in the parts arrangement could be to do with the horizontal outlet, mine is vertical.
Ewarts tap mysteries
Here are the components of my tap minus the cork:
I can spot two marks on the rear part of the plunger, they line up with the two holes coming from the inlet.
There is a brass sleeve in the rear end of the tap with one hole ( reserve?) and the front hole is in front of that sleeve where the cork sits.
So the plunger would go in like this:
Is this a worthy subject for…
Is this a worthy subject for the club Parts Commissioning scheme? I'd happily add my name to the I want one list.....
Petrol taps - renewing
While we are talking taps, the Ewarts tap cannot normally be dismantled, as the plunger is riveted together. However, new corks are available - I've seen them for sale at times - and if you get one, its an easy process to replace the old cork, without undoing the plunger:
1) Just remove the old crusty cork with a sharp knife
2) Boil your kettle and dangle the new cork in the steam for a minute
3) The cork will become pliable. Cut it neatly with a very sharp craft knife or scalpel, lengthways. into the hole in the centre, so that it opens out.
4) Feed the cork onto the plunger and insert the plunger back into the tap housing as soon as.
5) Because the cut was clean, the tap will seal.
Job Done
Hi Andy, I will try that…
Hi Andy, I will try that next time, I have always put the Knob in a small vice and punched the shaft out with a thin steel punch . Reversing the process on assembly and spreading the end of shaft out slightly into the knob reccess. . I have a couple of spare taps serviced and ready to swap as needed.They usually last for a few years depending on the quality of the cork. I dont know how they will last if E10 becomes the norm.
Just checked...
Just checked a factor in this saga. The groove for the screw is in line with the slot in my picture. This is out of a tap with the outlet vertical. But I have just pulled another one apart with a horizontal outlet and the Pull me Push you is exactly the same!! So me thinks one has to actually work out how the tap works when putting it back together. Or take note as you tear things apart. Not much of an excuse these days we all have phones that take snaps.
One final comment for the…
One final comment for the saga. The main enemy of corks is tank rust. The tiny particles are very abraisive and wear out the cork , worth flushimg the tank out whenever it comes off.
case closed
Thanks to Alan and Robert I now can assemble my petrol tap correctly.
Thank your for the help!
No problem there Robert - we…
No problem there Robert - we can have an in-depth discussion about what engine all is the best one to use in our engines! :-)
I have a ewarts 2 position tap that I bought thinking it was a Dommy one. Its now reconditioned but has a straight thro supply so you would need to fit an elbow . I have been convinced its a lightweight tap , but not ever had a lightweight can't be 100% sure. I think the thread into the tank is 1/8 BSP which appears to measure about 3/8" , Just as the 1/4BSP dommy thread measures about 1/2" Most confusing untill you realise that bsp sizes are related to the bore size that flows the liquid.
