000798 000801 000804 000807 000810 000813 000816 000819 000822 000825 000828 000831 000834 000837 000840 000843 000846 000849 000852 000855 000858 000861 000864 000867 000870 000873 000876 000879 000882 000883
side panel
Me again,
I have a left  side panel with the 'S" wire  type  front mount bracket fitted . I am fitting this to a mk3 commando, which I have fabricated two rear mounting brackets to suit the holes in the side covers. however, I do not know how the  front 'S" wire type bracket works . Does it use the  Dzues screw fitting - if so - how? can someone post a couple of photos showing how they work. Thanks in advance.
Parts 5 and 6 on this diagram
https://andover-norton.co.uk/en/shop-drawing/169/frame-swinging-arm-suspension-units
You may have to drill the hole on a mk3 frame
Privacy Policy
