Me again,
I have a left side panel with the 'S" wire type front mount bracket fitted . I am fitting this to a mk3 commando, which I have fabricated two rear mounting brackets to suit the holes in the side covers. however, I do not know how the front 'S" wire type bracket works . Does it use the Dzues screw fitting - if so - how? can someone post a couple of photos showing how they work. Thanks in advance.
Parts 5 and 6 on this…
Parts 5 and 6 on this diagram
https://andover-norton.co.uk/en/shop-drawing/169/frame-swinging-arm-suspension-units
You may have to drill the hole on a mk3 frame
