My bike stopped firing on the L/H cylinder, causing the engine fault light to come on. The firing issue has been resolved but the mechanic can't access the ECU to reset it. The bike is fitted with a SCS Delta (400 Series) ECU - does anyone know how to access this, or a dealer/garage that has the equipment to do this?
Norton locked the ECU when…
Won't disconnecting the…
Won't disconnecting the battery for a few hours do the reset?
SCS Delta seem to think that…
SCS Delta seem to think that my bike will have the Omex ECU as it's a 2018 model - they finished supplying Norton in 2016! Thanks for the input in any case!
Omex are not interested in…
Omex are not interested in helping, when SG Norton went into administration they stopped all support. That may have changed with TVS Norton making another 40 961's depending on which ECU TVS are using for these 40.
That's not good news -…
That's not good news - thanks for letting me know John Holmes!
Norton locked the ECU when they should not have, if you contact SCS they will give you the options.
One of the options, but check with SCS it will work with your ECU first.
https://www.scs-delta.co.uk/product-page/norton-961-communications-obd-lead
