Resetting Engine Fault light on 961 Commando Sport
My bike stopped firing on the L/H cylinder, causing the engine fault light to come on. The firing issue has been resolved but the mechanic can't access the ECU to reset it. The bike is fitted with a SCS Delta (400 Series) ECU - does anyone know how to access this, or a dealer/garage that has the equipment to do this?
Norton locked the ECU when they should not have, if you contact SCS they will give you the options.
One of the options, but check with SCS it will work with your ECU first.
https://www.scs-delta.co.uk/product-page/norton-961-communications-obd-lead
I suggest starting a thread on accessnorton forum. There have been many discussions on ECUs.
Omex are not interested in helping, when SG Norton went into administration they stopped all support. That may have changed with TVS Norton making another 40 961's depending on which ECU TVS are using for these 40.
