Can someone out there recomend a Air Filter for a monabloc carb. on a 1956 Dominator 88 Thanks very much for any replies, Campbell Adie.
Air filter fitted to Model 99
The Filter box is made by…
The Filter box is made by Norville , a bit pricey ,you also need a carb ring and rubber connector ,or better make up the connection yourself. Very fiddly to fit ,I had to do some filing of holes to line up with the tank mounts. The filter is a mini item . The box came unpainted , so will go rusty. Battery box and electrics will have to be moved to gain access. Something simpler may be a better bet?. I don't know if the big box filter will fit in the wideline arangement ,I have only seen it on a slimline.
Difficult to replace
My 1959 99 has the studs on the inside of the oil tank for a filter, but you have to take off the battery box when you need to change it - not very convenient!
I'm thinking of just using a mesh "fly-catcher" on a bellmouth - or maybe using something finer and up the main jet one size.
With normal classic use the…
With normal classic use the filter element will last for years . Happily with a DL I only have to remove the battery ,and that has to come out once a year to top up the acid anyway.A good mudguard is essential to protect the filter box from spray, or a baffle from guard thro the swinging arm which also keeps spray away from the chain.and box sprocket.
Hi Cambell, here are the pictures I took when I fitted an air filter to my similar Model 99. The filter housing I bought from an NOC member, unfortunately it has no makers name. It fits nicely to the inside of the oil tank, filling the space between the oil tank and battery box.
