Steve Jowett www1.kingston.net/~fortierg/mainb.htm
The same con rods were used on all twins from the 1966 650 up to the 850 Commando. They are exceptional rods and give long life. The rod was modified for the 1975 model along with its cap. Although I have found several references to this modification, I can find no reference as to why
Miscellaneous Specifications
| Material:- | Aluminum alloy B.S. L83 or 2L65 or L77 heat treated Dural tube 'B' or 'S' |
| Length (entres):- | 5.877" - 5.873" (129.276mm - 129.274mm) |
| Big End Eye i.d.:- | 1.8950" - 1.8955" (48.133mm - 48.145 mm) (less shells caps bolted on) |
| Width at Big End Eye:- | 1.010" - 1.008" (25.65mm - 25.60 mm) |
| Rod Side Clearance:- | 0.013" - 0.016" (0.330mm - 0.406 mm) |
| Rod End Clearance:- | Less than .001" (0.0254mm) |
| Conrod Bolt Torque:- | 25 foot pounds |
General Notes
I agree with the workshop manual in that when removing and reassembling the connecting rods, new shell bearings should be fitted. This is just good practice and for the number of times you would want to take the motor down to this stage it may save a few years towards that next rebuild. Make sure upon reassembly that you do not scratch or score the shells as they are easily damaged on the bearing face. Special care should be used when dismantalling the cases as the rods could hit the case and cause damage beyond repair. If the rods are nicked or deeply scratched, I would recommend replacement. Polishing the rods can help strengthen them but I would only do this for a racing machine. If you take material off as you would in polishing I would check the weight prior to and after removal. This will have an effect on balancing. Again I cannot stress enough about the cleanliness upon re-assembly. These parts are vital to the operation of your machine and any dirt that becomes lodged now could prove fatal later.
J.B. Nicholson - Modern Motorcycle Mechanics
750 cc Con Rods:- In 1966 when the oil pump
speed was increased and other lubrication modifications were introduced on the
750 and 650 motors a 1/16" diameter spray hole through the rod big end was
provided to give additional piston and cylinder lubrication. These rods should
be installed with the oil spray hole to the outside of the engine, i.e. away
from the flywheel on each side. This rod big end spray hole is not recommended
on the 1965 and earlier motors with the slower speed oil pump and if a later rod
is being fitted to one of the earlier motors the spray hole can be simply peened
shut from the outside.
Con Rod Nut Torque:- 1968 on
Norton specifications show an increase on this item to 25 foot pounds. The
earlier specification was 15 foot pounds. The 25 foot pound torque is considered
suitable for all 650 and 750 motors; these use 3/8" diameter bolts. On the
earlier and smaller twins models using 5/16" bolts, torque should be limited to
15 foot pounds.
Rod Bearing Caps:- It is essential that
these be kept with the rod from which removed and refitted so the cap is the
same way around with the register marks on the cap and the rod lined up.
Con Rods
| 1968 Commando | |||
| Fastback after Serial Number 126125 - Frame Number 126125 | |||
| Part No. | Description | Quantity | Models |
| 25369 | Connecting rod with cap | 2 | All |
| 23254 | Connecting rod cap bolt | 4 | All |
| 23253 | Cap bolt nut | 4 | All |
| 25384 | Con rod bearing shell (top half) standard | 2 | All |
| 23255 | Con rod bearing shell (bottom half) standard | 2 | All |
| 25409 | Con rod bearing shell (top half) 0.010" | 2 | All |
| 25410 | Con rod bearing shell (top half) 0.020" | 2 | All |
| 25411 | Con rod bearing shell (top half) 0.030" | 2 | All |
| 25413 | Con rod bearing shell (top half) 0.040" | 2 | All |
| 25165 | Con rod bearing shell (bottom half) 0.010" | 2 | All |
| 25166 | Con rod bearing shell (bottom half) 0.020" | 2 | All |
| 25167 | Con rod bearing shell (bottom half) 0.030" | 2 | All |
| 25168 | Con rod bearing shell (bottom half) 0.040" | 2 | All |
| 1969 Commando | |||
| Fastback, S and R after Serial Number 131257 - Frame Number 131257 | |||
| 1970 Commando | |||
| Fastback, S, R and Roadster after Serial Number 135140 - Frame Number 135140 | |||
| 1971 Commando | |||
| Fastback, Roadster, Hi Rider and SS after Serial Number 141717 - Frame Number 141717 | |||
| 1972 Commando | |||
Fastback, Roadster Roadster Combat, Interstate and Hi Rider
| 1973 Commando | |||
| Roadster, Hi Rider and Interstate | |||
| 1974 Commando | |||
| 1975 Commando | |||
| 064896 | Connecting rod with cap | 2 | All |
| 066486 | Connecting rod cap bolt | 4 | All |
| 067827 | Cap bolt nut | 4 | All |
| 064285 | Con rod bearing shells (pair) standard | 2 | All |
| 064286 | Con rod bearing shell (pair) 0.010" | 2 | All |
| 064287 | Con rod bearing shell (pair) 0.020" | 2 | All |
| 064288 | Con rod bearing shell (pair) 0.030" | 2 | All |
| 064289 | Con rod bearing shell (pair) 0.040" | 2 | All |
