Any advice on the correct size and type of lockwire for the cam follower securing screws on a '73 750 commando wiuld be appreciated. Thanks.
Andover Norton: part no. 13.1668
From Andover Norton: part no. 13.1668
Lock Wire for Tappet Plate Screws (for 4 Screws)
1.95 £ excl. VAT
in stock
https://andover-norton.co.uk/en/shop-details/20396/lock-wire-for-tappet-plate-screws-for-4-screws-
or beg a couple of inches of…
or beg a couple of inches of stainless steel reinforcement tie wire from a building site...it will be 1.2mm so make sure it will fit...
Fishing wire
A long long time ago I bought a small spool of monel trolling wire.
I would suspect that it will be available at any store that sells sporting or commercial goods for fishing especially if it is around a salt water area.
Still have quite a bit left.
Wire
There is an American company that makes locking wire, called Morosso, and it is a large roll. If you look on the Real Steel web site, www.reasteel.co.uk you will find it.
ordered from A.N, received…
ordered from A.N, received and fitted. Thank you all for your help.
Hello Norman
I don't have a definitive answer perhaps someone else will chip in.
There is some helpful information here:
https://www.accessnorton.com/NortonCommando/cam-follower-safety-wire.28809/#post-440656
Recommends 0.031-0.032 inch or 0.8mm stainless steel lockwire (or safety wire as it's known in the USA).
Andy
