Lockwire
Any advice on the correct size and type of lockwire for the cam follower securing screws on a '73 750 commando wiuld be appreciated. Thanks.
From Andover Norton: part no. 13.1668
Lock Wire for Tappet Plate Screws (for 4 Screws)
1.95 £ excl. VAT
in stock
https://andover-norton.co.uk/en/shop-details/20396/lock-wire-for-tappet-plate-screws-for-4-screws-
or beg a couple of inches of stainless steel reinforcement tie wire from a building site...it will be 1.2mm so make sure it will fit...
A long long time ago I bought a small spool of monel trolling wire.
I would suspect that it will be available at any store that sells sporting or commercial goods for fishing especially if it is around a salt water area.
Still have quite a bit left.
There is an American company that makes locking wire, called Morosso, and it is a large roll. If you look on the Real Steel web site, www.reasteel.co.uk you will find it.
