When is a leak not a leak
Bit of a mystery, for whatever reason, number 6 headbolt down,and number 7 sleeve nut up have always had a tendency to come a bit undone, ok, live with it and nip it up, but this timeI thought I"d overdone it and lo and behold, Oil collecting on the downside of the fins etc.  Head gasket,Argh!  Cleaned it all up,  no loud blaring so Winter project. Next few  times the same, but less oil to clean off . Last fast  run, nothing!  Had a closer look round, is it leaking from front brake callipers, having bled them the bleed screw always needs a return visit to make it "tight" , the tacho junction, it has leaked before,   Another look and the front R/H Isso  rubber has a split, this would explain the mess at that lower level again becoming less. Could it be melted grease rather than engine oil. It does seem less oily , bit harder to clean off/gung,
It sounds as if you need to get everything cleaned up and then try the old trick of sprinkling talc to identify the source of the leak.
But I think we need a fuller, less abbreviated account of your troubles in order to offer useful help.
