Wellworthy oil rings
Research suggests that 650 engines running the high pressure lubrication system with oil holes in the con rods are best fitted with "Wellworthy" oil scraper rings.
Before putting my engine back together with NOS Hepolite +010 pistons which came from NOC shop with rings already fitted, I wondered if there were any ideas where the best quality oil scraper rings may be available from.
Not had any luck with internet searches on this.
I got some multi piece oil rings for the Atlas from a piston and rings specialist , a bit like the old Cord rings and similar to those fitted to the engines with the 6 start pump gears . Turner and Cox I think.
