torque setting
Hello all , can anybody confirm the torque setting for the gearbox mainshaft nut on a 1972 commando ?
I have just fitted a new one and tried to torque it up to 70 LBS as per my manual . The thread on the nut has stripped . My torque wrench is good quality and I haven't had a problem before .
Any advice appreciated !
Check out Old Brits Norton Technical articals. They say 40 Ft/Lb and Loctite in Gearbox assemble.
My Factory MK3 manual says 40/50 FT/LB. Remember Torque settings are dry and not with grease on.
thanks for info Christopher , just looked at that and the recent Real Classic item , both quote 40-50 lbs .
Wish I had seen them before I did the job . My manual quotes 70lbs for main shaft nut at right hand end !
I think it must refer to the clutch , left hand , end nut .
I think the shaft thread is ok so I will try again with another new nut , RGM must think I have gone mad !
Watch the clutch side too as using the workshop torque risks collapsing the shims for the clutch centre.
