Hello everyone
Has anyone fitted one of the paper airfilters to an SU? After reading an article on the accessnorton web site (thread titled 'looking for better aircleaners for flat slide carbs') where someone had done some flow tests on various airfilters the original style paper airfilter came out tops in the amount of CFM compared to K&N's, Emgo, and plain foam types, I want to fit one of them as I don't like the amount of 'see thru' in the 'K&N' type airfilter I have currently fitted to the Mikuni I am replacing. If I can see thru the filter, dust and shite can get through it as well. Interestingly the article said that Fleet operators (presumably cars) had gone back to oem filters from K&Ns.
The photo is of the curved cable guide that I made to fit the throttle arm because i didn't like the cable flexing/rubbing where it exits the manifold casting.
Peter Shand
picture-006-large-jpg
I like the mod.....a reall…
Hi i used a standard back…
Hi
i used a standard back plate with single carb front plate with rgm narrower filter an inch smaller and made a plate brazed on a carb ring for and standard air box rubber to fit see picture.
Mick
sdc12572-jpg
Hi Mick Thanks for the rep…
Hi Mick
Thanks for the reply. Just the information I wanted, i.e. that it had been done.
Is that a priming pump fitted to the float chamber? If so, where did you get it?
regards
Previously peter_shand wro…
Previously peter_shand wrote:
Hi Mick
regards
Hi Peter
yes thats a primer its a briggs and straton lawn mower primer bulb with a base and cover i made up it works well its the type with the hole in and still acts as breather over flow got it off ebay.
Mick.
Mick, The priming difficul…
Mick,
The priming difficulties with the SU were one of the reasons I gave up with it and went to Mikuni. You seem to have solved this nagging problem.
Would you do a wrote-up for Roadholder together with some pictures so that everyone can know about it?
Previously Chris Grimmett…
Previously Chris Grimmett wrote:
Mick,
I have recently bought an SU kit for my 750 commando not fitted yet,how bad are the priming issues ? i had thought about using an aftermarket jet ski priming kit that plumbs straight into the manifold about £20 from evilbay ,i would love to know how you fitted your primer a write up in roadholder would be great cheers nick
Iâll add another vote for…
Iâll add another vote for a write up with a few more details of the primer pump you used. I had the same problem when I first fitted my SU some 30,000 miles ago, but have found that provided the bore of the fuel tap was similar to that of the inlet stub on the carb, I have no difficulty starting. My routine is, from cold, fuel tap on, full choke, ease over compression a couple of times & then a good kick. This almost always results in a first kick start. When the engine is hot, the same routine but with no choke, & with a warm engine, same again but with just a sniff of choke. If I donât ease over compression a couple of times, then itâll take two or three kicks to start. I have since fitted an SU to a second Commando & find that the same routine works for that also. The problem Iâve found is that quiet a lot of fuel taps only have a very small bore through them, & this restriction seems to cause very difficult starting with the SU. Strange, as you would think that once the float bowl was full, that would suffice, but opening up the taps really did make a huge difference, effectively from not being able to start it at all, to pretty much first kick all the time.
As for air filters, Iâve run the K&N for probably 20â000 miles, like Phil, I wash it out & re-oil once a year or so & have had no problems & noticed no excessive wear to either carb or bores. My foam filter disintegrated years ago!
Regards, Tim
Mick,
Hi Chris
will get some info together about SU carb mods i made primer,filter and throttle lever position etc Ken Weeks gave me the primer idear on last thread about SU and Tim Gostling helped out with info on taps and float level. PS a mk 2 primer is under way hopfully with no turning and not sticking out so far.
Mick.
sdc12513-jpg
I like the mod.....a really smart idea.
My Commando has a SU carb that originally came wearing a very fine foamy cylinder filter. This was washed each year and then oiled. It also had the oil tank breather passing through it and worked quite well until Ethanol came along and disolved it.
I then purchased a large KN type, cone shaped metal mesh filter. The cleaning instructions were the same with a yearly Paraffin wash and then an oiling. I was told that the oil helps to create an electro-static charge which makes the dust stick to the mesh. As before my oil tank breather is attached to the filter.
This set-up appears to work as when I pulled the pistons out, this year, to renew the rings the pistons and bores showed none of the fine scoring found in my unfiltered Dommie engine.
