Shock spring rates for Atlas
Can anyone tell me the spring rates for the Atlas ? Also the color codes on the springs if possible.
The Norton Atlas, 1965 on according to the Girling book, uses a spring rate of 110lbs. and it is 8 inches in length. The part number for the spring is 9054/277, This is Red/Red, Free length of 8.32 inches, minimum working length of 3.60inches.Normal length when fitted 8 inches. The spring code is 110RR80.The complete suspension unit is 4423, and the damper only was 4455.The normal fitted load is 35.
