Roadholder internal fork springs
Hi, Can anyone clarify the length that a Navigator fork spring should be ?
Part No for the Navigator is 23015 and an es2 is E2/620
Many thanks
... that the "lightweight" forks have lighter springs but someone more knowledgeable than I will no doubt be along shortly.
The lightweights were all fitted with a lighter fork spring. Colour coded green for identification.
This should be confirmed by the part number of Navigator spring being different from heavyweight spring.
Sorry I can't tell you length.
In reply to by peter_holland1
23015 spring - front forks.
Free length 18.062 ins min/18.312 ins max
73 working coils. Equispaced.
Wire 7 gauge, 0.176 ins dia.
Coil dia, measured wire centre to wire centre, 0.8 ins.
Both ends paint green.
Used on Navigator and Electra.
Enough information for anyone to get replacements made.
... can be confusing as often a part which was used on earlier bikes is carried across but with a different part number....
Ok well i stripped the forks out and what I found ! the forks were assembled with the correct green painted internal springs and also a pair of external springs ?? someone must have been using up their  spare parts :-)  well thanks for all your help and its now a comfortable ride
