Rear Brake drum/hub
Hello All, I'm playing around with the rearcushdrive hub and brake drum and a one piece spindle- I don't have the spacers - so how close does the drum fit up to the hub?
Thanks for your help
Martin
I've had a look on RGM's site and they give some dimensions to the hub/drum spacer 062070 but not thedimension that gives the required fit of the two parts - does anyone have one of these spacers to hand that they could measure for me?- see attached picture.
commando-wheel-spacer-pdf
PART No 0602070
Well thanks for the help chaps!!
I had to resort to putting my hand in my pocket and bought one (thanks NOCC Spares for the speedy delivery)- even though I have to make a custom one
For future reference should anyone need it I've measured it (see attached drawing):-
Measurements - the 16,99mm dia measured with a micrometer seems right to fit into the 17mm bearing diameter.
The 25,17mm dia would be a turned 1" diameter (with an open tolerance)
The length of the 1" diameter - 18,03mm I presume is 18mm plus a tolerance ( just over a thou) but the 31,79mm lengthis smack on 1 1/4" using a verniercaliper.
I believe that this part ended up being hardened as the earlierversion wore as they fretted up against the wheel hubbearing.
norton-hub-spacer-dim-pdf
I think others may, like me, have been unsure what you were asking about; to me "one piece spindle" suggests some kind of combination replacement for the wheel-spindle/dummy axle ensemble (i.e. parts 06.0289 + 06.2067)
Previously martin_seymour wrote:
PART No 0602070
