poor valve clearance
i am after a 2mm thick head gasket for my dommi 88. anybody making them to order?
A compression/base plate under the barrel would be better, then you can get the same effect with a normal head gasket. Available from the usual suppliers.
hi Stan,
i ve not seen anything on Andover Nortons website. so who do you suggest.
My engine is a little bit mix and match from different sources and the compression would be too high as it is.
Also a 1mm thick copper head gasket seems a little weak to me. i have read of using 2 head gaskets on a commando engine with similar clearance problems. Also, I would feel happier with 2mm thickness.
It should be possible to find someone with scanning and lazer cutting facilities to make cylinder base compression plates . Many years ago a private individual did just that to provide us with a 5mm alloy spacer for a complex primary cover for a Kawasaki race bike ,allowing the use of a wider clutch.  A common modification at that time. Pistons and valve lifters travel  will need checking .
