poor valve clearance
i am after a 2mm thick head gasket for my dommi 88. anybody making them to order?
A compression/base plate under the barrel would be better, then you can get the same effect with a normal head gasket. Available from the usual suppliers.
hi Stan,
i ve not seen anything on Andover Nortons website. so who do you suggest.
My engine is a little bit mix and match from different sources and the compression would be too high as it is.
Also a 1mm thick copper head gasket seems a little weak to me. i have read of using 2 head gaskets on a commando engine with similar clearance problems. Also, I would feel happier with 2mm thickness.
https://andover-norton.co.uk/en/shop-drawing/891/dommi-engine-500-600cc
See p/n 06.7171
https://www.rgmnorton.co.uk/buy/barrel-base-compression-plates-dominator-030-75mm_148.htm
out of stock but useful comment on fitting
I think you're asking for a blown head gasket if you go very thick or double up.
A 0.75mm compression plate + extra base gasket + standard head gasket will give you the equivalent of the 2mm head gasket you were after.
It should be possible to find someone with scanning and lazer cutting facilities to make cylinder base compression plates . Many years ago a private individual did just that to provide us with a 5mm alloy spacer for a complex primary cover for a Kawasaki race bike ,allowing the use of a wider clutch.  A common modification at that time. Pistons and valve lifters travel  will need checking .
