Hi
Does anyone know if when fitting a Pzon to a Commando you set the timing to 28 or 31 degrees when lining up the red dots?
Many thanks
Guy
You set the timing up on w…
Thanks Alan 28 degrees see…
Thanks Alan
28 degrees seems to be standard and 31 looks like the setting for Pazon.
Guy
You set the timing up on whatever setting you have decided on for full advance. As it looks like you are using the standard settings 31 deg. If you don't you have the Pazon instructions, they are here: http://www.pazon.com/files/pdf/pa2.pdf
Alan
