Can anyone help with the oil capacity for long Roadholder forks as fitted to my 1950 ES 2 ? My 1950 shop manual reprint lists the capacity as being 1/4 pint. I assume that this means Imperial pints which seems to be 568 ml for the pint and therefore 142 ml for the 1/4 pint. US fluid measure seems to be 473 ml for the pint and therefore 118.25 ml for the 1/4 pint, a difference of approximately 24 ml. I filled them using the Imperial figures but thought I should check as I don't know if 24 ml difference is significant - it doesn't seem to be much to me but as I am uncertain I thought it best to check- can anyone advise on this? Thanks in advance for any help- Richard
Hi Richard, I am also in t…
I think you are well withi…
I think you are well within the capacity that could cause problems. I used up to180ml in long roadholders. It is as Skip writes, suck it and see. Incidentally the real viscosity of fork oils bears no relationship to the weight or descriptive term given by the manufacturer. There is a fairly comprehensive table that has all the figures somewhere on the internet.
Alan
Previously wrote: Hi Richa…
Hi Richard, I am also in the USA & have long roadholders. I converted 1/4 UK pint to 142milliliters, which is about 5oz. I have an old kitchen measuring cup in the garage (dollar store find for, you guessed it $1) and it has metric and standard graduations, works great for fork oil. I think the measurement is just a guide though. I have found it also depends on what you use for oil, the Factoryrecommendedoil, FLM auto trans fluid (what I use) or any of the great fork oils on the market with anti foaming agents.
Seems like you did it right to me. The last time I overfilled a fork leg, it blew oil past the upper seals & made an oily mess whenever I hit a bump!
Skip
Skip- Thanks for the quick reply & for confirming what I thought - I used Morris 20 w from a gallon I bought years ago for these forks - so far I've used about 10 oz. so I think my children or their children will inherit some of it - Thanks again-Richard
Previously wrote: I think…
Alan
Alan-Thanks also to you for the quick reply- I,ve been working on this total redo for over 4 years now and it's almost done - just need to rig up a temp fuel supply while the tank is at the painters, screw my courage up tight and try for a restart ! Thanks again-Richard
Previously wrote: There is…
Alan
The manuals for short Road…
The manuals for short Roadholders say 5 fluid ounces or 142cc. My manual for long Roadholders does not say, but I am sure they are the same as the business end is similar.
Andy Mullins
Previously wrote: The manu…
Andy Mullins
The business end is not similar if you are referring to early Roadholders. My experience is that a low volume will produce insufficient damping. I tried different volumes over the years. What I didn't know then was the actual viscosity of the oil I was using.
Alan
Previously wrote: Can anyo…
hi richard, thanks for asking this. while i just rebuilt the forks on Ed (norton) this week i haven't fit them to the bike yet. i read the '57 19S manual and the 1/4 pint but it didn't occure to me about the imperial pint thing so i guess 5 oz (u.s.) it is. my manual call for 20wt s.a.e. but i figure 20wt fork oil will do just fine and i found i have some in the cupboard. Thanks for bringing this to my attention.
the other post caught my eye too about spring lenght and i'm gonna have a look at that in th a.m. when i go out to the garage and have a measure. curious minds need to know. regards, mike, melody and ed (norton)
Hey Richard, found this ge…
Hey Richard,
found this gem in a article in Real Classic Magazine:
And finally, for the bouncy bits. There's a fair bit of doubt among Norton owners when it comes to the correct amount of fork oil required for the Roadholder front end. 'Despite much confusion,' says Les 'you use exactly the same amount of oil for short, long and extra-long Roadholder forks. Use an SAE 20W, and each leg will require 150cc (five fluid ounces). The swinging arm uses EP140, and just fill up as required.'
Entire article:http://www.realclassic.co.uk/techfiles/nortonoil0908.html
Skip
Previously wrote: Hey Rich…
Hey Richard,
Skip
Hi Skip- Thanks for passing that info along- I restarted the engine last weekend - all went well but I was a little anxious as this was my first ever complete rebuild. As my tank is still out at the painter's I had to rig up a temp fuel supply which was leaking here and there so I didn't run it for long- Any credit for success belongs to Mike Pemberton as he coached me via e-mail and any errors are purely mine ! I know you are here in the states, but where ? If I get it completed in time I hope to bring my ES 2 to it's first event in mid-April at the annual Gathering of the Nortons at Washington's Crossing, PA- any chance you'll be there ? Thanks again- Richard
Hey Richard,
Skip
Hi Richard, I am 30 minute…
Hi Richard,
I am 30 minuted east of Cleveland on lake Erie. I am just wrapping up a '50 model 7. Congrats on your project! Job well done!
Skip
Hi Richard,
Skip
Hi Skip- I have a 56 Dommie 99 in "large lumps" as they say that I won off e-bay a few years back - it came from Erie PA so not too far from you I suppose-anyway I'll post pictures ( if I can get my daughter to teach me how) of the ES 2 here when I get the tank on . -Richard -toolboxlbi53@comcast.net
Skip
