Mk 3 master cylinder paint
Anyone suggest black paint for the master cylinder that is resistant to brake fluid ? Thanks, Roy.
Hi Roy
I believe AN powder coat their new master cylinders. If you are stripping and resealing caliper and master cylinder you could look at using silicone fluid, it it's not hygroscopic  and wont damage paint.
Best regards
Katherine Scott
Powder coating is as diverse as painting in types of powder, so be sure to specify a brake fluid proof powder or if not available use silicone fluid if you go that route.
Just finished renewing internal seals on cylinder. I'll give it a go. Many Thanks, Roy.
