Anyone suggest black paint for the master cylinder that is resistant to brake fluid ? Thanks, Roy.
Master Cylinder
Powder coating is as diverse…
Powder coating is as diverse as painting in types of powder, so be sure to specify a brake fluid proof powder or if not available use silicone fluid if you go that route.
Master cylinder
Just finished renewing internal seals on cylinder. I'll give it a go. Many Thanks, Roy.
Powder coating
Tell me. Had the outer engine covers on a Yr5 powder coated and they turned out to dislike petrol !! I learn. Thanks.
Hi Roy
I believe AN powder coat their new master cylinders. If you are stripping and resealing caliper and master cylinder you could look at using silicone fluid, it it's not hygroscopic and wont damage paint.
Best regards
Katherine Scott
