Master cylinder
The piston in the front brake /master cylinder moves freely but will not come out of the bore. I have removed the 10 tooth circlip and grommet. When I move the piston to remove it it stops with a metalic click. I have followed the Haynes Manual. I am obviously doing something wrong that will be so obvious but before I get the heavy mob in are there any suggestions?
Many thanks Roger
