Interstate LR tank replacement
Hi AllI have a 72 750 combat roadster, as I live in oz (Australia) I have been thinking of an interstate or LR tank to extend distance between refueling. Does the tank fit without any modifications or do I need to change the seat?
Thanks in advance
Mark
Nerang Queensland Australia
Prwith the interstate tank you will have to change the seat,not sure about the longrange tank because that was used with a fastback seat with the ears cut off ,do you have the original twin amals ? a single carb gives better MPG and a single SU gives even more MPG at the expence of top end performance ,if you go for a new tank be aware that the ones from india vary in fit and quality regards nick eviously mark_ross wrote:
Thanks in advance
Mark
Thanks in advance
Mark
Thanks for the info, As I have my Mk1 Amals set up so well I would shudder to change them. I get ok fuel consuption on them but do enjoy opening them up on the right peice of road. If you go west into the outback it gets a bit hairy between fill ups. I dont know about a tank from India though. I think I will try and find an interstate tank and buy a new interstate seat to swap over as required. Wish I could just buy an interstate commando to keep the roadster company, maybe in a year or so. I feel there is nothing sweeter to ride than a well set up Commando.
Thanks for your input Nick
goodluck with finding an original interstate tank make sure you get a steel one ,my glassfibre fastback tank has melted so i now have a roadster tank fitted i really miss that extra gallon !! regards nick
Melted?
If you want to do the full Interstate style Mark, remember the side panels can be changed too. Available new.
I have thought about changing to a roadster since my conversion to a single MK1 Amal and 68 mpg. A very smooth throttle action and the only performance loss is at the very top end. Worth thinking about.
yeah Thanks Nick Wouldnt go a fibreglass one anyway, We dont have ethanol in all our fuel over here yet and have a choice. we have 98, 95 and 91 octane and E10 and have just seen 85% ethanol advertised a week or so ago. 85% seems ridiculous to me but thats our government over here. Thanks for your thoughts.
Previously neil_wyatt wrote:
Melted?
Wow Neil 68 MPG thats pretty good I would only be using the interstate setup for long distance riding in remote areas, up and down the coast is all good PLenty of servo's. I really prefer the Roadster look although interstate commandos are a sweet looking peice, It will be the next one I restore,come to think of it all Nortons are special in their own ways. Maybe not the Hi Rider, but Im sure it had it's place Somewhere.
Thanks Neil
Hi Mark,
Yes, The Hi Rider was for the USA market mostly. Easy Rider.
If you search 'Neil's Norton Notes' you will see at the top of the page, me and my 76 Mk3 Interstate in front of Peel Castle, IOM. It was in a state when I bought it in 1988.
Not been to Queensland but I toured NSW in 2004. Nice to see your new government have done away with much of this Green rubbish. Sensible voters down under!!!!!!!
Iv just changed my Commando from twin Amals to single mk1, with standard jets etc. I rode it in the morning with 2 carbs, then in the afternoon with 1.
it was immediately apparent that the bike had lost tourque upwards of 2,500 revs, right where you need it for hills and overtaking. I have to take a bigger handfull compared to befor. It's obvious that will happen as the mixture has to go round two 90 degree bends.
As for mpg, I haven't done enough miles for a definative answer yet but it doesn't look like a vast improvement.
While I still had my twins on when my mate had a single mk1 on his Commando with 280 main jet and number 3 slide, my twin Amals were consistently better, although my engine was freshly rebuilt while his was a bit worn and smokey.
Overall I'm happy with the conversion- reliable tickover and no synchronisation to do, but I think it will only increase the range of a roadster tank from 110 to 125 at best.
Peter, is your Commando an 850? If so, after a lot of trials and error and a word with John Dunn, I found that 3 1/2 slides and a 260 main jet worked best.
If a 750 then I don't know. Of course no two bikes are the same but once you are happy with the set up I'd be interested to know what your MPG is on a run. You might be surprised. I was.
Neil
mine is a standard mk1 850, and I used the left hand carb from my twin Amal setup without changing anything in it ( 260 main jet, 3 1/2 slide ). I was surprised that it worked so well straight away. Starting is one or two kicks, tickover is steady after about 30 seconds of warm up. I used an RGM single carb air filer front plate so it looks standard from the side, and the twist grip action is so much lighter. The Mk1 Amals are such a simple carb to work on and I am familiar with them. I wish I had done this conversation years ago as I can live with the slight torque reduction.
I guess that slide wear will not be to bad as there is more of a constant suck through the carb from the two cylinders, whereas I think the slide rattles backwards and forwards when it feeds just one cylinder.
i will monitor the fuel consumption, but I'm not expecting a big improvement. Even if I got another 10 mpg ( which I think is unlikely ) it will only be another 20 miles on a roadster tank.
At the same time I did the carb conversion I also fitted an RGM Dave Taylor head steady. These two jobs together have transformed the way the bie rides for the better.
Peter, glad it's going well. Looking fwd to the MPG test.
When I found my original head steady plate cracking, I replaced the whole thing with a stainless Norvil item. This meant less engine shakes but a slightly less smooth ride at lower revs.
We agree that the single Mk 1 Amal conversion is a good move.
Hi Mark,
Dont misunderstand me Our government (Queensland ) have introduced some almost hitler type laws in regards to Motorcycle riders, On a 3 hour ride it is nothing uncommon to pulled over 2 or 3 times , and questioned for 20 minutes or so, then they go over your bike.
Our gov sucks mate and Im betting they wont make it past the next election.
i was born and bread in NSW, but spent 4 years in Western Australia Now that is bike riding country over there.
