I want to fit indicators to my 72 750. I am more interested in visibility, safety and reliability than originality.
Suggestions for nice looking modern alternatives to The Prince of Darkness originals
Can I use LED bulbs?
Nick
Hi the lucas ones can be m…
Previously nick_ohare wrot…
Nick
Hi Nik, I too have fitted…
Hi Nik,
I too have fitted Gen Lucas indicators this year after 32 years continuous Commando ownership. I got fed up with Jam Jars trying to knock me off on the way to work! No problems so far and easy to fit, I personally don't think the small modern types look right.
All the best.
I use std lucas. You can u…
I use std lucas. You can use LED but these will need to be +ve earth if your bike is +ve earth. If you use LEDs for front and rear you will need to change your flasher unit - I use LEDs for the rear indicators, but std bulbs for the front and the stock flasher is fine for this.
Hi the lucas ones can be made to work perfectly well, if you add an earth wire to each one, and use a modern flasher unit. Mine flash regularly at tickover and with headlights on.
