Horn switch
Can someone confirm something that has confused me with the horn button switch?
I'm re-wiring my Mk.3 and have stripped & cleaned all the handlebar switchgear.
The white wire supplies the power to the horn push which gives a live feed to the horn on the purple/black wire.
I couldn't find a purpose for the blue/white wire in the six core cable. After opening up the switch to see where it goes to, and finding it connects to the horn switch,I find it gets a live feed from the white wire when the horn button is pushed up rather than in for the horn.
Is this a main beam flasher, the markings on the switch case give no clue?
Yes, main beam flash and part answer to your previous post use separate exhaust pipe headers, with the flared end at the cylinder head, makes fitting the exhaust so much easier.
