Gearbox Identification N5083
Hi
I have a gearbox stamped N5083 which I thought was an AMC gearbox. I am replacing the kickstart shaft and purchased one for the AMC gearbox and the new one is not it is not the same as the one I have removed. basically the hole for the return spring is further up the shaft and in a different position relative to the kickstart pawl. looking at the images in the Norvil catalogue, the shaft I am removing looks simialr to the NA & MA box shaft (part number 040477).
Can anybody verify if the grarbox number does relate to a AMC gearbox so I can purchase the correct part.
Many thanks
