Hi, anybody in the Hampshire area know of a company that will supply & fit new bonded friction pads to my existing ES2 clutch plates? I’m rebuilding my bike after being boxed for 40yrs , the pads are dry & some are detached hence new pads required
NOC Spares
1960 ES2 clutch back plate
In NOC spares you show a clutch back plate less friction pads part no. 040353 where can I get the friction pads bond to this plate?
I think the 1960 clutch uses…
I think (not sure) the 1960 clutch uses all factory bonded friction material and replacement plates are the norm. .Its possible that you have an earlier clutch which could have some pads replaced and this is causing confusion ?.
https://shop.nortonownersclub.org/clutch-plate-friction-inner-tang-surflex
