I am sure I have seen on the forum an article detailing oil flows for the various Dommie twins but cannot now find it, Can anyone help with this please?
Previously jon_osborne wro…
Previously jon_osborne wrote:
Do you mean oil ways , and if so then the one to take care of is the one that runs at the back of the cylinder head and barrel , this is a return oil-way from the inlet side of the cylinder head , and it needs to be cleaned every time you have the engine dissembled , the other one it just as important and thats the oil pressure valve it need taking out and cleaning and checking of the fit as it wears too , the next in-line is the sump nut and its parts the fine brass mesh needs cleaning , it the first tell tail sign of any wear or trouble from the engine components with specks of metal trapped in the mesh , when fitting this back do make sure the cur-clip is located correctly , the oil-way for the rocker arms also need a clean out too, as does the oil tank from time to time and the filler mesh in the oil tank needs a clean , if you have the engine disassembled then you can also clean out the oil-ways in the right half the crankcase with a air line, or a air paraffin gun , keeping you oil clean is keeping your engine healthy ,
Yours Anna J Dixon
