Front Wheel Offset
Does any one know the offset on a commando 850 mk2 front wheel.i I measured mine and got 12mm from disc flange to side of rim and 21 mm on non disc side from hub side to rim side .wonder if this is correct?
It depends on what rim you have fitted. It's best to centre it in the fork legs, then centre the back rim  to match.
These are my measurements from an original 850 Mk2A front wheel:
Outside of disc to rim: 35.5
Rim width: 68.3
Overall width of disc: 21.7
So distance from disc mounting flange to rim is: 35.5 - 21.7 = 13.8.
As noted, you should work to the rim centre to allow for varying rim sizes thus,
distance from disc mounting flange to rim centre is: 13.8 + 68.3 /2 = 48mm [corrected 10 Dec]
