Differences in Dominator timing cases
Hi all, I recently bought a new (used) timing side engine casing of ebay. The pressure relief valve arrange is different to my current case. Firstly the 'new' case has a proper oil seal in the case, and the thread for the prossure relief valve is a lot larger than the valve in my old case, and there is also another threaded hole by the valve opening which I don't know what it's for.
I am trying to find out if this case is interchangeable with my old case, and if there are any benefits apart from the obvious one of a proper oil seal. Also, as my old pressure relief doesn't fit in the new case, if i'm going to use it what parts do I need? Thanks
Hi Jake - if you search for 'timing cover' you will find that I asked a similar question in February and received some helpful replies..
Thanks Colin, the search didn't find your post, but I was able to find all your content under your username and if I understand it correctly I can use any timing cover.
Previously Gordon Johnston wrote:
Jake, if you are stuck I might have the bits you require. Gordon.
Hi Gordon, Thanks I've PM'd you.
