Clutch pressure plate - the right one
I have a 1957 99 and 3 pressure plates, all with different depths can somebody tell me which is the correct part number and eventually the depth. This can also obviouslychange the way the springs are tightened, flush or not!!
On a related topic the centre adjustment nut seems to touch the interior of the tin chain case when pulled as there are marks inside, again there are two lengths of adjuster so which goes with which plate (obvious answer is long with shallow and short with deep but ????
Thanks for any reply
