Clutch centre nut with built in oil seal
I remember some time ago that a member had problems with one not fitting well I now need one any of you got a recommendation
Pete
No experience of the Comea…
thanks I now have seen a n…
thanks
I now have seen a nut with a built in seal from RGM has any one used them ?
Pete
I had one that was a thin…
I had one that was a thin nut that fitted on the end of the existing nut. When I stripped the bike down for a total rebuild there was only half of it left. Something had eaten it. Moths probably.
Previously peter_mietus wr…
Pete
Pete
i think it was my previous post you recall. The RGM seal wouldn't fit and I returned it. The Dave Comeau seal was perfect and cheaper to buy.
david
Pete, search for "RGM Clut…
Pete, search for "RGMClutch nut" and you'll see the previous post with all the details.
RGM were only selling the…
RGM were only selling the large nut with seal - for Dominators. For the Commando, I had to get the thin nut with seal from Norvil
Previously david_lord wrot…
Pete
Pete
david
thanks all I'v now seen t…
thanks all I'v now seen the Dave Comeau unit on the USA site and it looks like Norvil sell it 068833 £22.09 +VAT
Pete
I bought mine direct from…
I bought mine direct from Dave and it cost considerably less than Norvil
Thanks I have emailed Dave at dynodave@atlanticgreen.com on Monday but I have had no reply is this the email address you used
Pete
Pete just go to Dave Comea…
Thanks David I have been u…
Thanks David I have been unable to order from the web site and have sent 4 email to Dave over the last 2 week but have had no replies
Does anyone know if he is still in business? Or have an alternative email
Thanks Pete
No experience of the Comeau seal but have heard they can just hold on by 1 thread if the existing dimensions are not beneficial!. Alternative ways to stop or slow oil migration are a groove and 'O' ring about an inch in from the clutch end (depth of groove appx. 0.040" and a ring to suit so its just proud of the surface). That has worked for me for 8 or 9 years now. Or, cut the shaft in half, remove 1/4" and add a 1/4" ball bearing. Its probably a good idea to surface harden the cut ends with one of those powder compounds the cherry red shaft gets dipped in. Haven't used that stuff for years..........last time was in '85 on a clutch pushrod for my old Camaro. That worked well for hardness and was a 3/8" rod.
