Atlas camshaft
I am rebuliding a 1965 Atlas engine, it was down because one of the cam followers had failed (Stelite tip broken off)
It had a non-standard camshaft in it (3 key ways where the sprocket fits), the owner tells me it was some kind of "Lumpy" cam.
I have been offered a Model 88/99 cam and followers which i have been told will work, but has less lift (0.302" instead of 0.332" in the Atlas).
I am trying to rebuild this on a budget, so can anyone tell me if this Cam will run satisfactorily in the Atlas, maybe i will lose some performance, but the owner is only looking to use it on a few rideouts now and again. I am just trying to save him the £400ish on a new Cam and followers !
Its been off the road for at least 20 years and would be nice to get another Norton up and running !
Cheers Ian
Cheers Ian
I can't think of any reason this should not work, try to match up which follower worked on which lobe, compare the breather parts as they changed sometime.Use 3 and 5thou clearances,performance loss will be minimal.The 88/99 cam needs to be Daytona type.
Agreed. No noticable loss in performance (unless you insist on exceeding 6,000 rpm and even then would you notice?). I used 88/99 followers successfully in my Mk 3 Commando after a stellite tip broke off. Does the camshaft need to be the Daytona type? Can't see why. Gordon.
Cheers Ian
Hello Ian You need A SS cam Marked X1 or early commando cam will do but the followers must match the camshaft and there the Flat Type Cam Followers you must have the breather holes I the Middle and the end of the cam must have the fitting for the disc valve for the breather hope this helps
Thanks for all the help, its nice to know there are fellow Norton owners out there willing to help.
Kind regards, Ian Hind
067817 Standart cam, 067817/2S 2S cam, both available as Genuine Norton Factory Parts from Andover Norton. To be used with flat camfollowers.
