Can anyone tell me where the Slide Cutaway number is measured from? I've currently got a No 3 cutaway and want to try a 3.5. My Idea is to alter the other No 3 that I have sitting doing nothing to the dimensions of a 3.5, if someone has a 3.5 or a 4 that they can give me sizes from I'll have a wee bash at altering my spare No 3 to suit.Ok buying a 3.5 would be easy but why not have a wee go with a half round file and a bit of fine emery ?
As it happens, Amal supply…
You will need a flat file.…
You will need a flat file. The cutaway is a flat chamfer
I have used this method a…
I have used this method a few times just be aware its easy to take too much off! there is very little between a 3.5 and a 3 cutaway but it makes a big difference,,,,,,,,,,,,,,,,,nick
Previously wrote: As it ha…
As it happens, Amal supply that information on their web site:
Previously wrote: I have u…
Thanks Nick, I'll have a wee bash and see how it turns out.
Mac.
Had a root through my "Box…
Had a root through my "Box of bits" today and found the slide that I was going to take my file to was already marked up as 3.5, saves me a job,bonus!
Now I'm 99.9% that this is what I want but when you look at the table on the Amal site http://www.amalcarb.co.uk/TechnicalDetail.aspx?id=11%C2%A0%C2%A0%C2%A0%C2%A0 it says that it should be stamped as 3 1/2?
I suppose 3.5 is easier to stamp than 3 1/2, is this correct or does anyone know different?
