I am considering replacing my switchgear with aftermarket kit, but this will give me problems with my master cylinder. I was already considering the mod to reduce the diameter of the cylinder as I want to retain the original caliper.
is there a good 12 or 13mm master cylinder with a brake switch built in that anyone has changed to, for example Brembo?
Try Holland Norton Works:…
Mine is off a suzuki
Can't remember which model but it solved my wooden brake issue.
https://www.carpimoto.it/en…
https://www.carpimoto.it/en-GB/Brand_Brembo/42207_10462095-Brembo-PS-13-Brake-Master-Cylinder.htm
or
https://www.carpimoto.com/en-GB/51016_10505351-Brembo-PS-13-Brake-Master-Cylinder.htm
but the remote reservoir might upset some people...
Same parts can be found in UK at higher price. Be sure to read CarpiMoto's terms for Britain post-Brexit.
Triumph Master Cylinder
I'm rebuilding a Commando and I've used a Triumph master cylinder. They are available with 12 / 13 mm bore and with a stainless steel body. The hope is that it will give the bore size advantage and be more durable. The switch is integral with the banjo bolt and sourced separately and you need to have a special hose made with a banjo at the top. The lever is chrome rather than aluminium but the difference is not obvious and you can't fit a Norton lever. It took a bit of Googling to find the parts but it looks 'factory fit'. I've not run the bike yet. M/C was from E-bay, I think it's Harris and was cheaper than a stock Norton M/C, switch was from a company that supplies car parts (it works just fine, the pressure must be similar), hose was Goodridge, made at a Goodridge supplier that usually supplies parts for race cars, while you wait service. Hope that helps, can post a photo if you like? Best to bleed it all on the bench before you fit it.
Andover Norton front master cylinder
# 13 mm front master needs 13mm unit.
OK = installed Andover Norton Triumph T140e unit 06.7163 from Classic Bikes - Standard 13mm unit fits direct onto existing Norton controls (1977).
Brake hose cover (elbow) from Triumph T140e 60.4186
# Fit break sensor to new front master cylinder brake line.
OK = New kunifer and switch fitted between yoke’s (tree).
Thanks for everyone's input…
Thanks for everyone's input.
My replacement switchgear arrived from Aliexpress and there was no left hand switches! Looking at their website, it was very misleading, I thought I was buying both sides but it was not the case!
But the quality was, not too surprisingly, not as good as I hoped. It was cheap, worth a punt, but you get what you pay for!!
Also, with trying to get a suitable master cylinder, it was all getting a bit too difficult.
So back to plan A. I have gone for the RGM reline kit and the original switchgear that I have now refurbished.
https://www.hollandnortonworks.eu/en/exclusive-commando-parts
