Re the ignition switch on a 99 dommi, Mine can be turned either left or right with the key and starts in either position. . Why and what is the reason of this.
Previously wrote: Re the i…
Yes If this is the PRS8 sw…
Yes If this is the PRS8 switch with the little spade ignition key switch down the middle of the lights switch. If converted to 12V all this is lost by the way.
AO
Robert, I strongly recomme…
Robert, I strongly recommend you get a manual or handbook for the bike. If nothing else they will give you all the basic data and instructions for the controls, starting and stopping as well as general maintenance - the last point is VERY important of course. You can get photocopied manuals from Bruce Main Smith, originals rep[roductions from the usual Norton spares suppliers and CDs ofscanned copies from eBay for not much money. I have all of these for all my bikes! In the case of my Norton 99 I havethree originalP100 1959 Maintenance Manuals! Just being greedy! If I had your email address I could send a pdf.
The advantage of electronic versions is that you can print off what you need for a job and nor worry about getting it dirty!
Cheers, Lionel
