850 Mk3 Commando Starter Motor Seal
I need a part number for the garter oil seal in the drive end cap please.
I have found a number for brushes AND seal, but do not require brushes as I am fitting a four brush prestolite conversion which is already aquired.
Regards,
John
You will most likely find that the four brush conversion doesn't improve the performance of the two pole prestolite much, if at all. You must address the rotor moving towards the drive end plate and wearing its self away. Easily seen when the motor is apart.
John,
066310 is the part number quoted on the Norvil website - not seen it offered elsewhere.  Listed as £3.63 plus VAT.
Andy
