Hi Graham, Just so you dont…
Hi Graham, Just so you dont get a mix up later ,the 19 tooth engine sprocket makes the gearing lower (not higher) than normal and coincidentally makes it slightly harder to kick over than the correct sprocket would . Takes a bit of mental juggling to accept !!. The cold clatter is fairly common on the Atlas and is piston slap that eases off as the motor warms up . Some did it from new. The HC pistons also are heavier than the orriginal dished ones and also can have extra thick strong gudgion pins that add weight . If you ever get it apart it would benefit from a re-balance that just might reduce the vibes . We geared our Atlas up with a 21 tooth sprocket, only just enough room and it has helped . (but its still a booger to kick over ).
I hate to start an oil…
I hate to start an oil thread, but I see this as snake oil. For example, have a good read through:-
https://www.gtr.co.uk/threads/ametech-engine-restore-oil.66347/
And a number of other forums.
And make your own mind up.
My precious motorcycle…
My precious motorcycle engines would never forgive me if I contaminated their life blood with something that resembles a scam product without me firstly conducting a Q&A with my preferred engine oil company saying it was safe to use in their products.
The previous comment with its forum link says all there is to say on the "additives" issue. The date line may be 14 years or so but the comments are still valid today outlining the same lack of credible positive back up and referral literature.
Caveat emptor anyone?
Take a look.
Oil manufacturers invariably…
Oil manufacturers invariably add the caveat not to add anything to their oils, in my experience. I would be particularly circumspect where adding modern very slippery additives to classic mineral oil is concerned. It may quieten things down a tad short term, but what lasting damage could it do to, say, cams and followers? It starts to get expensive then....
I'll stick with regular oil changes and a full flow filter.
This bike is a doddle to…
This bike is a doddle to kick over. Starts first kick from cold or hot.And I constantly get mixed up with "higher - lower" gearing jargon.
The Ametech has definitely done something though. I could feel the engine and gearbox were smoother on a runout yesterday
Sawdust in the sump was…
Sawdust in the sump was alleged to be a used car salesman trick...seriously, is this something to make the seals swell? If so, will they soften and wear away, then dry out and be worse?
A bike thats easy to kick…
A bike thats easy to kick over is usually well loosened up and often performs well. Sometimes its the last hurrah ! before a rebuild become due. The Atlas will rumble on for years if not abused . Oil burning is the driver that will provke a rebore/re-ring and valve job , then its back to a stiff lump to kick over till it settles down .I think the additive is reducing the piston slap and hence the vibration. There is also the brainwash effect too !.
It's definitely smoother at…
It's definitely smoother at cruising speed. I can just feel it. The engine does use a bit of oil which I keep topped up. Let's face it, I haven't even had the engine apart other than to set the tappets. No telling how much wear there is in there. And who cares! It starts easily, runs really well and hasn't blown up yet. And everytime I take it out I have a grin so wide you could slip a double decker bus through it. What's not to like.
The RGM anti wet sump valve works but not 100%. If I leave the bike for a few weeks the oil level in the tank does drop a bit. Soon levels itself out though once it's done a few miles.
Overall, it's a really good bike for a Sunday blast of no more than 50 miles or so, which is all I've used it for to date. If I was serious about doing long mileages on it (like riding to Germany to see my daughter who lives there) I'd definitely recondition or renew the oil pump beforehand. I'd also change the small engine sprocket so I could do some higher speed cruising. But for now it works for me and so far its been a total hoot!
Not much point in having a…
Not much point in having a rev counter on the Atlas, a blanking plate on the cover and reduce the weight by putting the clock and bracket in the cupboard.
Robert, its all about self…
Robert, its all about self codology to which I am a prime paid up member to.
To have a rev counter on any supposed "fast" bike makes me feel to be one of the racing community with none existent racing skills never mind bravery to any great extent.
So leave us to our illusionary fantasies and to keep our rev counters to savour that inner glow such emotions evoke as we don our mark eights and take a blast down to the end of the driveway.
I am minded to think the…
I am minded to think the same as I think of the fuel "catalysts" that are available. No properly researched explanation as to how they work. Just unfounded claims of the veracity of the product.
One explanation as to how Ametech works suggest that it deposits a compound (metal?) on the worn surfaces. How does it know whats worn? Can it detect the worn area in a cylinder, perhaps "blow by" causes a reaction that deposits a layer (of something) in this area?
Lots of negative/cautionary…
Lots of negative/cautionary opinions here as I expected there would be.
I spoke at length with the suppliers of Ametech and read up on the technical literature. There's quite a lot of valid data that explains in detail what it does and how it works.
Just out of interest, I also plopped a "Fuel Diamond" in the petrol tank before taking the bike out for its first road test last August. It purports to reduce the acidic content in low grade fuel and increases the octane rating, thereby enabling older vehicles to run better on unleaded modern fuels. I purposely filled up since then with E10 even though E5 is available. It's good for 5 years apparently. So, six months later, I took the carbs apart a week ago to have a look inside. I don't use this bike a lot and expected to see at least some emulsification, oxidisation etc. They were clean as a whistle.
Just sayin'
p.s. if the ol' Atlas seizes up or blows up you'll all be the first to know about it.
Technical literature
Graham Z, do you have a link to the tech literature?
I knew a chap..
..who fitted so many fuel saving devices on his car, he had to drain the petrol tank every week to stop it overflowing...
For more info on RESTORE CSL…
For more info on RESTORE CSL@Engine Restorer & Lubricant please visit www.ametech.co.uk. Tech Helpline: 01728 726620
Link doesn't work
so went to the "americantechnology" site, same thing? Lots of words about what it is claimed to do but no explanation as to how it does backed up by the science it uses to achieve the claimed results.
I've got all the literature…
I've got all the literature here in hardcopy. I'll scan it at some point and upload it
Why do they never explain…
Why do they never explain why it tastes of liquorice?
Active8
You must have seen the demo at the shows. Works in an old laydown box I had trouble getting a clean gear selection. Poured the rest in the motor and felt a much cleaner rise through the rev range.
PS: should the mudguard stays be black, not chrome? That will surely affect airflow?…. :~)
They demonstrate it at shows…
They demonstrate it at shows.
That’s not a good sign!
STP oil treatment
STP Oil Treatment is good at rejuvenating tired oil seals, this is a tip the old man gave me, he ran Earles Fork BMWs and replacing the rear main oil seal behind the clutch is a pain, so he told me that half a tin of STPOT added to the engine oil at the next change will soften the seal enough to start working again in about 300 miles, and you know what, it does, more often than not.
And it is nothing like £24 for 400ml.
Yeah £24 is a fair bit of…
Yeah £24 is a fair bit of cash for 'snake oil', its true.
Took it out last weekend for another thrash (and believe me, I don't spare the horses on this ol' beastie) and it just feels better than it did. I've gotten a feel for this bike since I started riding it and I can tell there's an improvement. Can't say any more than that really. Smoother at cruising speed, more responsive on the throttle and the leaks that were there on the box aren't leaking any more.
Oh, and it didn't blow up. Result!
Some snake oils do work …
About 20 yrs back I put a Teflon type snake oil into my diesel engined van and when I picked up my mate to go to work he said after a few miles “ vans running lovely what have you done to it ?
Subsequently did around 300k miles on that van
I remember Raymond Baxter…
I remember Raymond Baxter showing a demonstration of a Teflon oil on Tomorrows World.
The outcome was convincing proving its efficacy I must say. That was the last I heard about it until today.
That “Teflon” oil additive…
That “Teflon” oil additive might have been Slick 50.
Here a link to a court case that went against the makers. https://www.ftc.gov/news-events/news/press-releases/1997/07/quaker-state-subsidiaries-settle-ftc-charges-against-slick-50
“ My Teflon “ product wasn’t…
“ My Teflon “ product wasn’t slick50 though I cannot remember the actual name all I know is the engine was smoother running and overall quieter to the point that it was like comparing old tech diesel injection to new tech diesel injection, anyway it isn’t Norton so I’ll sign off on this now
This is interesting stuff. Ametech Engine Restorer. Not cheap. £24 for 400ml but it appears to work pretty well. I actually bought it to put into a '78 Honda CB400N I'm restoring for my son but I only needed 250ml to do that so I used the leftovers in the Atlas
The AMC gearbox had a leak on the kickstart and gearchange spindles. Not much but a bit annoying. I poured a small amount (about 50ml) into the box. The main engine has never been apart since I've owned it. Doesn't give much trouble but it has a few weeps here and there and is a bit clattery when cold. It also vibrates, but I have no other Atlas's to compare it with so can't say if that's unusual. It's got a 19 tooth engine sprocket so gearing is higher than normal. I poured 100ml into the oil tank.
After 100 miles or so the gearbox stopped leaking and felt quite a bit smoother with slicker gearchanges than before.
The engine has always been pretty much a first kicker, probably due to the Thorspark Electronic ignition unit I fitted and it's always felt pretty lively, albeit with vibration at higher revs. Since having the Engine restorer in it's noticably smoothed out, has less vibration and better pickup when opening her up. Particularly at cruising speeds, which is between 50 & 60mph on this high geared machine, it's much smoother.
I did my due diligence before using it and spoke to the suppliers at length. It's difficult to say what it's done but I'd definitely say that all round it's a better more enjoyable ride.
Just sayin
