I recently replaced replaced the PRV on my mk3 850 as a previous owner had tightened it up with a chisel !!!! I noted that there were no shims behind the spring as shown on the parts diagram. Are there shims only required to take up wear?
The shim might be in the…
Fitted as required, maybe in…
Fitted as required, maybe in this case none are required.
The shim might be in the piston.
