Amal StayUp Floats??
I'm assisting a friend ('74 850) who has messed around with his fuel levels and new floats to the point where he is totally lost. Could someone advise on this adjustment as to whether the Burlen instructions setting fuel level with the float bowls off the bike will achieve a proper level when installed on bike?
http://amalcarb.co.uk/new-amal-concentric-stayup-float
Thanks,
My experience with stay-up floats on my T150 was that Burlens' instructions get you in the right field, that's all. Some bikes are more fussy about fuel levels than others. In the end, the only way was the old routine of a clear tube rig from a float bowl drain and see where the fuel ends up, then adjust accordingly. I set mine off the bike so the fuel level was around 5 mm below the top of the fuel bowl. Drained off and tried it twice to be sure, runs a treat, except the thing's way too big and heavy for this old guy !
Regards all, Terry.
My Premier StayUp floats were virtually parallel to the bowl top flange as delivered I found a slight tilt down at the front is the best setting to prevent leaking and still give the optimum fuel level on my Commando.
This prevents possible float contact with the upper carb casting and won,t overflow if the fuel tap is left on between rides. Just make sure both floats are set the same and the stainless float arms don,t touch the bowl edges as they swivel. This is easy to check by holding the carbs level and filling both bowls.
I find this the most effective method of setting StayUps rather than measuring float or fuel level height. Fine tuning can then be done via the needles, idle screws etc.
....did you set them initially with the bowls off the carbs and level?
Thanks,
Yes, stainless 2BA socket cap screws with short and long ball Allen keys make it easier to remove and fit the bowls than Phillips. Handy for float setting and synching the slide lifts too.
A good tip is to make sure the pivot shaft is tight in the slots so it doesn't move when you press lightly down on the stainless tab to check the StayUp height.
Once the floats are set and don,t leak you shouldn't need to touch them again for many thousands of miles,
Here are some pix of the same type of setup on my older Premiers. I have a better side shot of both floats at their correct heights but can,t find it at present
Important to push on the tab as he shows on photo. Not on the needle valve.
